1986 Suburban Bogs Down at 65
MEATLOCKERMIKE
I just bought an 86 suburban off ebay and I have been told that it has a problem with fuel delivery. I was told that it has a new mechanical fuel pump, but when driven at 65 or so it tends to bogg down. If the gas pedal is released and then applied again, it will work normally again. I was also told that it probably only needs an electric fuel pump. Does this make sense to anyone out here? If so, where would I find the fuel pump, is it an in the tank set up? Any help would be greatly appreciated.
Apr 27, 2006 at 10:49 PM
BURRBRIAN
  • 158 POSTS
Mike, as far as I know your mech. pumps are run off a cam lobe and are located at the pass. side, lower front corner of motor on chevys, elec. pumps can be in tank. I would check the fuel lines and see if you have any kinks or crimps in it that could slow down fuel flow. Also, the fuel filter could be getting kinda dirty from what you described.You can get weak pumps right off the shelf from parts store, too. Even if it's new it might still be your problem. Do you have carb or throttle body? Maybe the carb could be part of problem, too. Just things to look at,hard to pinpiont like this but these are where I'd be looking first. Lottsa luck :lol:
Apr 28, 2006 at 12:35 AM
Suggested Repair
Inspect the fuel lines for kinks or crimps and check or replace a dirty fuel filter. Test the mechanical fuel pump even if it is new, since a weak pump is possible. Also confirm whether the engine uses a carburetor or throttle body, because the carburetor may be contributing.
Conversation Summary
The owner of a 1986 Suburban reports bogging around 65 mph that clears after releasing and reapplying the throttle. A new mechanical fuel pump is said to be installed, and an electric pump was suggested. The expert explains that mechanical pumps are cam-driven at the passenger-side lower front of Chevy engines, while electric pumps can be in-tank, and recommends checking the lines, filter, pump, and carburetor or throttle body.
