cranks with key removed but never starts
SPVC1
1999 GMC suburban 143,000 miles cranks and continues to crank with key off and removed.
Never even trys to start,I changed the ignition harness and still does the same any ideas?
Jan 4, 2007 at 10:28 AM
BACKYARDMECHANIC
  • 337 POSTS
Sounds like the solenoid on the starter is engage all the time. Check to see if there is power to the solenoid all the time. If not the solenoid is making contact all the time causing the starter motor to engage without the key. Good luck :)
Jan 5, 2007 at 1:58 AM
