abs light problem
JAAS
if my brakes are low on my 2002 gmc yukon will it cause the abs light stay on constantly?
Aug 22, 2007 at 2:11 AM
CLY
  • 308 POSTS
No....the brake pads do not have sensors or anything on them. There is something going on with the ABS. You can go to a local parts store and most of them have a code reader to scan the codes and get you started in the right direction...
Cly
Aug 22, 2007 at 10:59 AM
JAAS
[quote:64f445aaea="Cly"]No....the brake pads do not have sensors or anything on them. There is something going on with the ABS. You can go to a local parts store and most of them have a code reader to scan the codes and get you started in the right direction...
Cly[/quote:64f445aaea]thanks,for that info it really helped,ill go get the abs checked.
Aug 22, 2007 at 3:04 PM
CLY
  • 308 POSTS
No problem...let me know what code they find and will see if we can work through it to get it solved...
Cly
Aug 23, 2007 at 12:05 AM
JAAS
[quote:058e9940d4="Cly"]No problem...let me know what code they find and will see if we can work through it to get it solved...
Cly[/quote:058e9940d4]
Aug 25, 2007 at 10:29 AM
JAAS
i had the abs checked,its the abs module ,how difficult would it be to replace it myself with a new one?(im no mechanic)
Aug 25, 2007 at 10:34 AM
CLY
  • 308 POSTS
The abs module is pretty easy to replace, BUT it will have to be programed to the vehicle. I don't know if anyone but a dealer could do it.
Cly
Aug 25, 2007 at 9:53 PM
JAAS
the reason i would like to do it mysel is because at the mechanic shop they would charge me $1776.00 for part and labor thats a too much,,,,would the same abs module of another 2002 gmc yukon fit,or will it still have to be program by a specialist?
Aug 27, 2007 at 12:58 AM
