'99 GMC suburban (still powerless)
1999 GMC YUKON
THANDORF
Changed water pump, reconnected bat. No juice. Checked fuses, found aux b burnt, and replaced. Also checked main ground, cleaned. No juice, and i mean no juice anywhere, hood light, interiors lights, nothing anywhere. I'm lost. And yes, I started it before i began replacement of water pump.
Jul 13, 2007 at 8:28 AM
CHEVY22
  • 1,375 POSTS
check your cables again , one may not be connected or corroded
Jul 13, 2007 at 8:36 AM
THANDORF
cleaned em up, no juice. hooked my car up through jumpers, still nothin anywhere.
Jul 13, 2007 at 8:52 AM
CHEVY22
  • 1,375 POSTS
if it was ok before you started , should be ok now , a water pump job is very simple and no wiring involved , retrace your steps and let us know
Jul 13, 2007 at 9:14 AM
THANDORF
looked over everything again, no loose wires, and cleaned all the ground posts, straps, wires. still nothing. Checked fuses again, nothing. Put a sledge through the windshield,...... nothing. The reason i disconnected bat. in first place, was for me not to have a shocking experience, but i believe i am in more shock now with no power. Think im gonna try jumpin again, and see if anything magical happens. ty for the help.
Jul 13, 2007 at 9:53 AM
THANDORF
jumpin didnt work, still lost on this one.
Jul 14, 2007 at 4:23 AM
CHEVY22
  • 1,375 POSTS
this may shound dumb but was the battery hooked up wrong ,
also you could try juping the cables and bypass the battery
let me know
pay close attention the the hot cable make sure its not fried anywhere
Jul 14, 2007 at 5:18 AM
