2007 GMC Yukon low oil pressure
SHALAN222
Engine Mechanical problem
2007 GMC Yukon V8 Two Wheel Drive Automatic
2004 yukon denali with low oil pressure message. Gage reads 0 at idle and about 20 driving. Changed oil pressure switch and oil pump. Problem persits. Now i have a nocking on engine. Out of ideas.
Jun 27, 2010 at 8:14 PM
  • 31,937 POSTS
Hi there,
You will have to check the oil pressure with mechanical gauge, if the pressure is still indication low, you will probably have a bearing problem, the knock is a problem, that will be lack of oil to a bearing.
Mark (mhpautos)
Jun 27, 2010 at 10:46 PM
