there is only one fuse for the wipers. If you look on your fuse panel underhood all the fuses will be marked as to what they are. Also your owners manual will do the same . It may be the switch, if you are the original owner an dhad the extended warranty check with the dealer thay may fix it at reduced cost if you b**** enough.
May 26, 2010 at 2:35 AM
