2007 GMC Yukon intermediate wiper fuse
2007 GMC YUKON
60,000 MILES • V8 • 4WD • AUTOMATIC
REDWINGONEPM
can you tell me what fuse controls the intermediate wipers?
May 12, 2010 at 3:40 AM
HMAC300
  • 48,601 POSTS
there is only one fuse for the wipers. If you look on your fuse panel underhood all the fuses will be marked as to what they are. Also your owners manual will do the same . It may be the switch, if you are the original owner an dhad the extended warranty check with the dealer thay may fix it at reduced cost if you bitch enough.
May 26, 2010 at 2:35 AM
