I recently had a bettery draining overnight and replaced the battery. Since then I have had to jump start the vehicle every morning. once started and running for 10 minutes the vehicle will start up all day no problem. Once it sits overnight it needs to be jumped again. I have checked everything to make sure nothing is plugged in ,lights on, xm/navigation turned off and cant find anything on. Checked all fuses and cant find the issue. I was told to remove one terminal and make sure everything is off and if I see a spark I have a short somwhere. I did do this and got sparks. All terminals are clean and tight. Thank you for your help! Will donate if helped Thanks
Brian
Brian
Nov 24, 2008 at 1:07 PM
