2005 GMC Yukon Driver Side Cold/Passenger Side Hot
2005 GMC YUKON
88,286 MILES • V8 • 2WD • AUTOMATIC
MARCUSPETERSON
I have a manual climate control in my truck, and when I turn on the air conditioner, I receive cold air through the driver side vents, but hot air through the passenger side. Also, if I turn on the heater, the same result occurs. What could cause this problem?
Marcus
Oct 28, 2008 at 8:17 AM
DENNYP
  • 1,824 POSTS
Sounds like a bad temp door actuator on the bottom side of the HVAC case.
Oct 28, 2008 at 8:32 AM
DENNYP
  • 1,824 POSTS
see if the actuator moves when you use the temp controls.
Oct 28, 2008 at 8:33 AM
