2004 GMC Yukon Oil Pressure Loss, Coolant burn-off & En
101,000 MILES • V8 • AWD • AUTOMATIC
BEWHOF
My Yukon has been losing some oil pressure about 800 miles after an oil change. Concurrently, I have had to start refilling the coolant reservoir tank frequently. There is no sign of a coolant leak. Engine also has developed a loud knock at startup, 30 seconds later it is gone. The knocking is worse as oil pressure decreases which occurs as time passes from oil change. When checking or adding oil I have also notice some white residue on the oil fill cap. Definately feel like coolant is getting into oil. What could this be?
Jan 23, 2008 at 11:21 PM
  • 75,988 POSTS
Get the oil presssure checked to rule out the oil pump -also for the white residue could mean blown headgasket/cracked head and block get it pressure tested.
Jan 23, 2008 at 11:31 PM
