2004 GMC Yukon Interior Temperature control
ROBX
Air Conditioning problem
2004 GMC Yukon
I have had continuing issues with the heating/cooling system.
Now when I am calling for heat from the front and rear system and from both passenger and driver air vents the drivers side and the rear units are heating but the passenger side is cooling, not outside air cool but air conditioning.
I have turned the vehicle off and on several times and the entire heating/cooling system but the problem persists.
Nov 8, 2008 at 2:15 AM
DENNYP
  • 1,824 POSTS
You need to have the BCM scanned for codes. It sounds like you are having a problem with a temp door actuator.
Nov 19, 2008 at 8:11 AM
