Shakes when I hit the brakes?
68,000 MILES • V8 • 2WD • AUTOMATIC
YUKON_714
my truck starts shaking really bad when i hit the brakes on the highway. what do i need to do?
Nov 18, 2008 at 10:57 PM
SQM
  • 6,383 POSTS
Just to clarify, it only shakes when you apply the brake at highway speed, and no other time?
You could have a worn lower ball joint or lower control arm bushing.
https://www.2carpros.com/articles/how-to-release-a-ball-joint
https://www.2carpros.com/articles/lower-control-arm-bushing-replacement
It could also do that if you have a out of balance tires.
I have attached the control arm and ball joint replacement procedure for your reference. Also included on how to check for worn out ball joints and control arms.
Jul 30, 2021 at 3:55 PM
