2004 GMC Yukon air bag sensor
2004 GMC YUKON
RJIVEY02
Electrical problem
2004 GMC Yukon All Wheel Drive Automatic
How do I change the air bag sensor under the passenger seat of my 2004 yukon. I have the part.
Mar 29, 2009 at 8:58 AM
BRIAN 1
  • 1,030 POSTS
before you do anything,read this info first:Replace the passenger presence system as a complete assembly to prevent possible injury to the occupant. The bladder, the pressure sensor, the seat cushion, and the control module are assembled and calibrated as a unit. Using only some of the components in the service kit will cause the passenger presence system to operate improperly. the PPS module also has to be rezeroed with a tech 2,or it will not function properly.The passenger presence system (PPS) is a calibrated system that requires rezeroing when the system has been serviced or replaced. this is not a do it yourself job,I would leave it to the pro's.
Mar 29, 2009 at 2:26 PM
