2003 GMC Yukon Wipers stay on
GGORLICH
  • 2003 GMC YUKON
  • V8
  • 4WD
  • 110,000 MILES
The wipers in my 2003 GMC Yukon intermtantly won't turn off. When this happens the delay function does not work, but the speed and washers functions do.
Thanks
Tuesday, June 22nd, 2010 AT 4:05 PM
SATURNTECH9
  • 30,869 POSTS
Which model yukon do you have there is six different models for that year.
Tuesday, June 22nd, 2010 AT 6:38 PM
GGORLICH
It is a Yukon 4x4 SLT 5.3 flex fuel
Wednesday, June 23rd, 2010 AT 8:02 AM
SATURNTECH9
  • 30,869 POSTS
I also need to know if it's a XL and if it's C1500 2500 etc. Let me know.
Wednesday, June 23rd, 2010 AT 11:58 AM
GGORLICH
It is a 1500. It is not an XL.
Thanks,
Greg
Thursday, June 24th, 2010 AT 11:22 AM
SATURNTECH9
  • 30,869 POSTS
I emailed you the trouble tree and wire diagram to your personal email.
Thursday, June 24th, 2010 AT 2:52 PM
POPAUL
Hi saturntech9 and ggorlich I have the same issue. Mine is a 2004 Yukon SLT1500 5, 3L vortech around the same milleage, so ggorlich is your problem fix? How do you fix it, and if its with the wiring diagram can you send it to me saturntech9?
Tuesday, December 28th, 2010 AT 9:44 PM
POPAUL
Saturntech9 can you send it to me too.
Tuesday, December 28th, 2010 AT 9:45 PM
GGORLICH
Hi Popaul,
I put a new wiper motor from a discount auto parts store, and it did not solve the problem. It ended up being the circuit board on the motor that was not rebuilt with the motor. The part you need is GM part # 88958136 It is available from GMpartsdirect. Com for $77.27. I had mine fixed at the dealer for about $462.00. I hope this helps. If I had to do it over again, I would have bought a new Motor from GM parts direct. Good Luck
Tuesday, December 28th, 2010 AT 11:22 PM
GGORLICH
Test
Tuesday, December 28th, 2010 AT 11:24 PM
POPAUL
Thanks its realy appreciated I was hoping fixing it today cause I have a 12 hour road trip this night I guest ill have to deal with it till I get back home. Thanks again for the advice and answering so quick.
Wednesday, December 29th, 2010 AT 3:09 AM
