2003 GMC Yukon Water Temperature Sensor
2003 GMC YUKON
80,000 MILES • V8 • 4WD • AUTOMATIC
MCHLDELF
I have a 2003 GMC Yukon XL 5.3 liter 4 wheel drive. I am having a problem with the Yukon wanting to stall when I back up or come to a complete stop. I was told by a local shop that my water temperature sensor or the coolant sensor are probably bad. Any suggustions would be great. Also where would I locate the water temp sensor? thanks
May 19, 2010 at 8:01 AM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
most common culprit for an engine that stalls when coming to a stop or in reverse is a faulty torque converter.. i don't see how temp. sensor would have anything to do with it stalling but the engine coolant temp. sensor is on the front side of the left cylinder head.
May 19, 2010 at 4:51 PM
