2003 GMC Yukon SPARK PLUGS
68,000 MILES • V8 • AWD • AUTOMATIC
LAKERS20
I have a 03 Yukon Denali XL and just had my spark plug changed. Everything seems to be running good but I am just wondering . Do you set the gap of the spark plugs to your car specifics or the gap that is set on the new plugs. How Would I know if the plugs were installed correctly and what is the gap size on a 03 XL DENALI???
May 23, 2008 at 12:34 PM
  • 31,937 POSTS
Hi there.
The plug gap should be .060" or 1.52mm. This should be checked with a wire type gauge. All plugs are pre gapped, but a good mechanic will re check when installing. The only way to check them is to pull a plug and re check gap.
Mark (mhpautos)
May 23, 2008 at 10:45 PM
