2003 GMC Yukon Right Turn Signal
61,000 MILES • V8 • 4WD • AUTOMATIC
OYA97
My left turn signal works fine but on the right side it doesn't work in the front, rear, dash or mirror but makes the clicking sound and when i turn the right signal on all three back break lights starting flashing, bulbs are fine, fuses are fine, so I am confused as to whats wrong, help please?
May 30, 2010 at 3:39 PM
FACTORYJACK
  • 4,159 POSTS
Have you specifically checked the RT TURN fuse in the left I/P fuse block. I would check that it has power when the RH turn signal is on, with a test light.
May 31, 2010 at 5:44 PM
