2003 GMC Yukon Lo beam headlight drivers side not working
BUCKEYE13
  • 2003 GMC YUKON
  • V8
  • 4WD
  • 75,000 MILES
The low beam headlight on my 2003 Yukon does not work. I have changed blubs, checked and changed fuses, and installed a new relay switch for the low beams. None of these have fixed the problem.
The low beam on passenger side and the high beams work fine.
Any suggestions on what the problem could be or how I can fix it?
Sunday, December 30th, 2007 AT 8:22 AM
  • 31,937 POSTS
You will have to check the continuity of the power wire for this light, start at the light and work back untill you find a broken withe or a faulty pin in a plug, I would tend to think it is a faulty plug connection.
Mark (mhpautos)
Monday, December 31st, 2007 AT 5:51 AM
