2003 GMC Yukon Drivers Power seat and Both seat heaters
88,000 MILES • V8 • 4WD • AUTOMATIC
MOW ED
My 2003 Yukon has a problem with the drivers side power seat (all functions) and Both power seat heaters not working. These functions worked one day and didn't the next.
This vehicle has the auto recall seats and everything associated with that works except for the seat recall.
I replaced the 30A circuit breaker located under the drivers side inst panel next to the steering column but that did nothing but cost me 14 bucks. The other fuse I checked was a 10 amp per the owners manual and it was fine. I looked at various other fuses and found nothing. I looked under the seat to the best of my ability and really didn't find any bad wires. (there may be some but it is hard to trace). The seat functions of the power passenger seat does work so my problem is exactly with the Drivers Power seat functions and Both seat heaters. Any help is appreciated. If I can save money by not taking it to a dealer and fixing it myself I am certainly willing to shoot some bucks your way. Thanks. Ed
Feb 4, 2009 at 12:15 AM
BRIAN 1
  • 1,030 POSTS
follow this info,Some customers may comment that the seat heater and/or memory seat functions are inoperative.
Cause
A logic lockup of the memory seat control module may cause this condition.If the seat is currently inoperable, perform the following diagnostic steps to determine if replacement of the memory seat control module is the correct repair:Connect a Tech 2 to the vehicle and monitor the parameters in the sensor data list for the driver seat module as you try to move the seat. Are the displayed data parameters changing, or does the Tech 2 display no communication as the seat switch is moved to various positions? If the data parameters do not change, the memory seat control module may be inoperative due to a logic lockup.
Remove the SEAT circuit breaker in the instrument panel relay block located under the left side of the instrument panel next to the parking brake. This circuit breaker also supplies power to the passenger seat.
Verify that the circuit breaker is not open. If it is not open, wait 30 seconds and then reinstall the circuit breaker.
Try to move the seat again.
If the seat moves or the data parameters displayed on the Tech 2 change when the seat switch is activated, replace the memory seat control module. Use the Memory Seat Control Module Replacement procedure If the memory seat is still inoperative, use normal Service Manual diagnostics to determine the cause of this condition. follow this info and post back with what you find.
Feb 4, 2009 at 4:35 AM
MAC9955
There's two nuts that need to be removed under the driver's side front seat, once removed the seat comes loose, disconnect some of the wiring and you'll see a black box, that is your module
Feb 27, 2009 at 8:00 AM
KANE878823
Does not address how to remove the nuts if the seat is stuck in a position that blocks the 2 nuts. Plus there are also 2 bolts?
Nov 17, 2025 at 1:19 AM
  • 55,673 POSTS
Yep, that is a tough one, if the seat does not move the nuts will need to be cut off using a air hammer chisel.
Nov 18, 2025 at 1:42 AM
