2003 GMC Yukon Battery replacement
2003 GMC YUKON
75,000 MILES • V8 • 4WD • AUTOMATIC
CGAETA01
i replaced the original 600 cca batter with a 700 cca. Is this bad for the car, specifically the starter...can it burn it out? are there any other concerns?
Thanks.....
Jan 6, 2008 at 9:53 PM
The CCA is only for cold cranking which the starter needs to operate effectively during a cold start. especially in freezing weather conditions. The higher the CCA the better it is. You can go with a 750 if you wish.
Jan 6, 2008 at 10:37 PM
