RPM's go from 2000 to 4000?
150,000 MILES • V8 • 4WD • AUTOMATIC
SUZANNEMANGINO
What does it mean when you are driving 60 MPH on the highway on flat ground with a full load and the RPM's go from 2000 to 4000. Transmission fluid and oil levels are full.
Mar 2, 2009 at 12:01 PM
SQM
  • 6,383 POSTS
If you did not change the throttle input then it sounds like the transmission is downshifting.
If it does that without any input on your behalf, it can be due to transfer case control module. It can be due to the transfer case 'thinking' you need to be on four wheel low and triggering that.
Transfer Case Shift Control Module is located on the left side of the instrument panel.
I have included the reprograming and replacement procedure for that module (look below).
https://www.youtube.com/c/2carpros/featured
Sep 20, 2021 at 3:29 AM
