Shuts off after driving a short distance
235,443 MILES • V8 • 2WD • AUTOMATIC
MB-POWER
  • 80 POSTS
Hi all,
after starting engine and driving for one or two km, engine turned off automatically. some times when restart again it has come on , but most times no and I have to wait up to twenty minutes with a lot of restarting . another one or two km , engine will off again!
fuel pump has been replaced .
relay of fuel pump is too hot ! also relay of ignition switch !
scanned but no fault code .
when I turned ignition switch to on (without engine start) check engine light should be there , but most of times it is not on , only some times .
can you help please?
thanks
Jul 8, 2017 at 10:54 PM
HMAC300
  • 48,601 POSTS
check all your fuses first it may be a blown fuse not allowing the light to go on. then even if fuel pump has been replaced check fuel pressure and try a security system reset. See link and picture.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jul 9, 2017 at 2:51 AM
MB-POWER
  • 80 POSTS
can you believe it! the new OEM fuel pump was bad also.
another used fuel pump has been replaced and every thing is okay now!
Thanks for every body.
Jul 9, 2017 at 11:05 PM
HMAC300
  • 48,601 POSTS
if it was a Delco that is hard to believe but not impossible they are one of the better ones on the market and mostly trouble free. least it is fixed now. Thank you for using 2carpros.
Jul 10, 2017 at 12:26 AM
