Hi all,
after starting engine and driving for one or two km, engine turned off automatically. some times when restart again it has come on , but most times no and I have to wait up to twenty minutes with a lot of restarting . another one or two km , engine will off again!
fuel pump has been replaced .
relay of fuel pump is too hot ! also relay of ignition switch !
scanned but no fault code .
when I turned ignition switch to on (without engine start) check engine light should be there , but most of times it is not on , only some times .
can you help please?
thanks
thanks
Jul 8, 2017 at 10:54 PM
