I was driving home on day from work and a ticking noise started under the hood. It almost sounds like a rod nocking but I still get the same performance and my oil pressure is the same and no smoke from the exhaust . I took it to a local mechanic and he gave me a estimate for 3000.00 to change the camshaft all the lifters and rods. Also to change the timing chain and the cylinder head and gasket. He said it sounded like a collapsed lifter.? If it is a lifter or rod why does he need to change everything else? Is it possible to just change out the rods and lifters without changing all the other stuff on this type of vehicle.(2002 yukon 5.3L V8 2wheel drive)
Sep 29, 2008 at 5:50 PM
