Noises problem
2002 GMC Yukon V8 Four Wheel Drive Automatic
I have a noise coming from under the front of the vehicle , the noise sounds like whining of tires and disappears when vehicle is at low speeds. I thought was tires. I have replaced tires, the noise is still there? I am thinking front left wheel hub? How can I tell if this noise is a carrier bearing or axle noise versus a hub bearing?
appreciate any insiight you can shead on this?
thanks
thanks
Feb 13, 2010 at 5:47 PM
