took my truck to the gmc dealer for adiagnosis of a lack of power. the truck seemed to run good at an idle but lugged when i got on the throttle. i was told that it was missing on number six and it was either a broken valve spring or a fuel injector. at this point i took the truck home and did some looking.
-pulled off the valve cover, springs ok -changed fuel injector, no change -did a compression test, 150psi -did a compression test with both ajacent plugs removed, 150psi -moved plug, lead, and coil to different hole, no change -tested fuel pressure,ok -tested with noid lights, ok -sprayed intake while running with cleaner found no vacum leaks. please help
Jan 12, 2009 at 7:05 AM
