2002 GMC Yukon help
ENVYUZ
2002 GMC Yukon Two Wheel Drive Automatic
my 2002 gmc yukon will not turn on in park but it will on nueteral.
Feb 8, 2009 at 2:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty or ill adjusted Neutral/Park Safety Switch. Most newer vehicles' switch can be adjusted. Be sure to test after adjusting so that it will only start in Park and Neutral. If adjustment does not solve the issue, the switch will need replacing.
Thanks for using 2CarPros.com!
Feb 8, 2009 at 7:01 PM
