2002 GMC Yukon Headlights do not come on.
120,000 MILES • V8 • 4WD • AUTOMATIC
SIR WILLIAM
My Yukon's low beam headlights do not come on, ever. All of the other lights work properly. I read the User's Manual and checked the methods found there to turn the headlights off, but none were the culprit. Is the relay the problem? Thanks.
Apr 11, 2008 at 2:30 AM
RHALL77
  • 3,361 POSTS
i think there is a seperate fuse for each headlight. Did you check the fuse block under the hood?
Apr 11, 2008 at 2:50 AM
SIR WILLIAM
Yes, I checked all of the fuses; they're fine. Looking at the "fuse box" legend, it appears that the headlights are wired through a relay. Perhaps the relay is bad or it's the circuit breaker the owner's manual talks about. Thanks!
Apr 11, 2008 at 7:23 AM
RHALL77
  • 3,361 POSTS
did you check to see if you have power to the electrical connector at the head lights?
Apr 11, 2008 at 7:28 AM
SIR WILLIAM
Replaced the relay; works fine!
Apr 18, 2008 at 3:47 AM
EDEFRANCE
I have the exact same problem. What is a relay?
Jun 8, 2008 at 3:13 AM
GSCHALL
  • 10 POSTS
I never heard of a relay, but if you can tell me where it is I will replace it no questions asked.
appreciate your response on this very much.
Thank You!
Jun 8, 2009 at 5:20 PM
