2002 GMC Yukon grinding noise front end
2002 GMC YUKON
56,000 MILES • V8 • 4WD • AUTOMATIC
SILVERBUZZ
When I turn to the left, I heard a grinding noise which eventually goes away. I also hear the noise occasionally when I go over a bump in the road.
I had the front driver's side tire removed and the pads and calibers appear okay.
May 11, 2009 at 1:53 AM
MIKE H R
  • 3,094 POSTS
the brakes may be ok but did you check the bearings? have the front jacked up and with the tire on see if there is any play when you try to move the tire back and forth and up and down. grab a hold of the tire on top and bottom and wiggle it up and down. If there is play then have the bearing checked. Also check the universals on the front shafts. Note check both sides I have seen bearings making noise coming from one side only to be bad on the pther side, so check both sides
May 11, 2009 at 2:28 AM
