2002 GMC Yukon fuel problem
130,123 MILES • V8 • 2WD • AUTOMATIC
JOE5150
HI: I have a 2002 yukon that i've been having replace the fuel pump every 3 to 4 months the past year. I have replaced the connector at the pump,filter,pressure regulator. i change the fuel filter every month and the fuel that comes out is black every time. i have checked and cleaned the ground wire on the frame. I dont know what else to do about this problem i hope you can help. thanks JOE
Mar 22, 2009 at 3:17 AM
JDL
  • 16,098 POSTS
Hello, what kind of gas are you using, have you tried a different brand? Is the gas tank/s clean? Oem pumps?
There are bulletins about not running E85 in a non-flexfuel vehicle. I don't know if that would turn the gas black?
Mar 22, 2009 at 3:32 AM
JOE5150
The yukon is flex fuel. and i have tried napa fuel pumps. but the last 5 have been acdelco mu1378 pumps
Mar 22, 2009 at 3:43 AM
JDL
  • 16,098 POSTS
http://www.acdelco.com/index.jsp
If nobody else has any better ideas,
Have you tried talking to acdelco? Do they have any ideas? There is a contact link at the bottom of their page. I've emailed them a few times about some of their parts, they always reply, sometimes it takes a day or two.
Mar 22, 2009 at 5:07 AM
