2002 GMC Yukon Front Brakes
2002 GMC YUKON
76,000 MILES • V8 • 4WD • AUTOMATIC
PAUL EDSTROM
I tried removing the front brake caliper assembly to change the brake pads, but after removing the two bolts it wouldn't slip off the discs. Is there some kind of a safety pin the holds it on once the bolts are removed? The assembly was loose and I could slide it three-fourths of the way off, but then it gets caught on something preventing me from getting it all the way off.
Thanks.
Feb 18, 2008 at 2:00 AM
DENNYP
  • 1,824 POSTS
Use a large screwdriver or small prybar to pry the caliper assembly off the rotor. You can also try to compress the caliper piston slightly to loosen the caliper.
Feb 26, 2008 at 12:46 PM
