2002 GMC Yukon automatic door locks
92,000 MILES • V8 • 4WD • AUTOMATIC
BLACKBIRD97
My automatic door locks quit working. They wont lock or unlock. I can press the lock button and nothing happens, but when I press unlock I can hear clicking from he fuse panel inside the car. How can I find out what is wrong?
Sep 7, 2010 at 5:18 PM
FACTORYJACK
  • 4,159 POSTS
Is this with the remote as well as the lock switch? When you are attempting unlock, and you hear the clicking, are the doors already unlocked. What happens if you manually lock them and then press unlock? If the work, try swapping the lock and unlock relays in the I/P fuse block, if they now lock, replace the one relay that is now in the unlock cavity.
Sep 8, 2010 at 3:21 AM
BLACKBIRD97
It wont lock or unlock with the remote or the switch. Replaced all relays and fuses in both fuse panels under hood and inside car still nothing. With the driver door open the security light stays on solid. As soon as I press the unlock button the security light flashes. I removed the negative battery cable for 1 hour. Hooked it back up door locks still dont work. What to do now? I do have an after market alarm system.
Sep 9, 2010 at 2:34 PM
FACTORYJACK
  • 4,159 POSTS
The security lock flashing at unlock indicates the factory system is disarmed. An aftermarket alarm does present some other possibilities. Is it the factory keyless transmitters that you use, or the aftermarket ones? If the alarm has an integrated keyless feature, the system has to be tapped into so the alarm module can control the lock/unlock functions. There is no standard on aftermarket installations, it is at the discretion of the installer. Since you hear relays in the I/P fuse block when you activate locks, the vehicles keyless system sounds as though it's functional. With the fact that the aftermarket system is in place, normal vehicle architecture may be affected, and therefor factory information would be useless. The first approach that I take whenever aftermarket equipment is installed, is to remove the aftermarket equipment.
Sep 13, 2010 at 3:05 AM
