2002 GMC Yukon
MDM
Electrical problem
2002 GMC Yukon V8 Four Wheel Drive Automatic
turn signuals stop flashing when brake is applied
Mar 17, 2009 at 3:15 AM
JDL
  • 16,098 POSTS
Unless your talking about trailer lites, the brake lites shouldn't effect the turn lites? I just wanted to add ,on some systems the lower brake lites are wired through the turn signal switch. Unless you talking about trailer lites, your brake lites are not wired that way. There could be a problem with the ground circuit? I'd check for voltage and ground at the suspect circuits.
Mar 17, 2009 at 4:01 AM
