2002 GMC Yukon
2002 GMC YUKON
66,000 MILES • V8 • 2WD • AUTOMATIC
JARR301
I could not start my yukon , gas gage said no gas low fuel light comes on ,but I have 10 gallons in the tank, I checked all the fuses and the relay they are ok, so I changed the fuel filter, the pump and the new censor that comes with it, there was fuel pressure but now there is not, my auto scanner says no link for only that car. what should I do ????
Oct 29, 2009 at 1:09 PM
  • 110,240 POSTS
Were you getting power to the pump? If the relay is good, you should be getting power to the pump. If you're not, then chances are there is a broken wire between the relay and the pump.
Let me know what you find.
Oct 30, 2009 at 2:50 PM
