windshield wipers not working
MIKE WAGNER
Four wheel drive automatic 90,000 miles
Hey guys, After changing the wiper blades the passenger side wiper stopped working. Drivers side wiper is working fine, but passenger side does not. Wiper fluid comes out it, it just will not go like it should. What do you think the problem could be?
Dec 20, 2007 at 1:07 AM
SULPIZIO69
I noticed the date, two years old. I am sure you have gotten this fixed by now or sold the vehicle by now. I was going to suggest checking the nut holding the wiper blade. I had a similar problem on my 2005 Yukon. On blade got frozen in ice and backed the nut off. It is an easy fix.
Dec 2, 2009 at 11:24 AM
OPRAM
V8 all wheel drive automatic 65,000 miles
I got in my car after a snowstorm. When I turned on my wipers the passenger side wiper would not return to its original position. It kept stopping higher and higher until it finally went under the driver's side wiper. I pulled it back to its original starting position, and after that it no longer worked. Any idea what i could do?
Jan 4, 2017 at 8:19 AM (Merged)
MASTERTECHTIM
  • 4,750 POSTS
check at the base of the wiper arm, there is usually a black plastic cap. pop it off and tighten the nut underneath it, they usually loosen up.
SONSHYNE
My power windows and windshield wipers stopped working. the radio comes on for a short period of time and goes off. if i hit a rough area in the road or if i push the button for the windows the radio shuts off as if it loses power. the guy at Meineke said it is the body control module. Please help me i cannot afford the shop or dealership.
HMAC300
  • 48,601 POSTS
sounds like a ground loose when you hit something hard it moves and things quit. it may be on left hand side of dash.
JBRONCO
V8 four wheel drive automatic
I recently purchased this SUV it is the XL model and i started having some electrical issues. It started with the door locks not working, then the power mirrors stopped working and know the windshield wipers are not working. They quit working once before but then they started working again. My question is do all of these components have a common part such as a relay?
LTNASH
V8 all wheel drive automatic 136,600 miles
During a storm the other day the right side wiper quit working while the driver side wiper continued working. What is going on?
