When turned on, turn signals and hazard lights do not come on. Fuse is in working order
Jan 19, 2008 at 12:08 PM
MASTERTECHTIM
✓Experienced Mechanic
most likely you have a bad turn signal switch. check to see if your brake light work. if they dont then your turn signal switch is definately the problem. feedback is greatly appreciated.
