2001 GMC Yukon turn signals and hazards
2001 GMC YUKON
12,500 MILES • V8 • 4WD • AUTOMATIC
LDJONESY
When turned on, turn signals and hazard lights do not come on. Fuse is in working order
Jan 19, 2008 at 12:08 PM
MASTERTECHTIM
  • 4,750 POSTS
most likely you have a bad turn signal switch. check to see if your brake light work. if they dont then your turn signal switch is definately the problem. feedback is greatly appreciated.
Jan 19, 2008 at 12:33 PM
