How do you reset the "Change Engine Oil" indicator? Is there a reset button somewhere, or another trick to it? Thanks.
Mar 30, 2008 at 3:02 AM
SERVICE WRITER
✓Experienced Mechanic
Turn the key to the on position, pump the accelerator 3 times within 5 seconds and it should start flashing, then stop. IT should be set at that point. This guide can help as well.
