2001 GMC Yukon rear brake rotor removal
90,000 MILES • V8 • AWD • AUTOMATIC
BRIHUTCH13
im having problems removing the rear brake rotors from my yukon. i looked at the new rotors i purchased and from the looks of it there may be something i need to do to the emergency brake or something. ive tried pounding away with the 3 pounder to no avail. is there something im supposed to disconnect or something im missing? and yes i have already removed the calipers, pads and caliper brackets. any help would be greatly appreciated. thanks.
brian
Aug 23, 2009 at 5:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
remove 2/3 of brake fluild from master cylinder reservoir, remove brake caliper and pads. rotor should be able to slide off if you have these off. brake heat may cause them to be stuck on and require banging on it with a rubber headed mallet.
Aug 23, 2009 at 6:44 AM
