2001 GMC Yukon low idle
35,000 MILES • V8 • 2WD • AUTOMATIC
BTHOOD2002
My engine idles at 4 to 5000 RPM's. It sometimes dies. The MIL light does not come on, and there are no pending codes. When I press the accelerator, it will rev and run fine with no problems. In fact, it idles so low the A/C will not come on till it goes up to about 7000. I have a Silverado with the same engine and year. It idles at 7 to 8. Any suggestions?
Brian
Aug 30, 2008 at 4:48 PM
2CARPRO JACK
  • 11,533 POSTS
Try cleaning the Idle Air Control Motor. Also clean out around the butterfly in the throttle bore with carb cleaner and a rag. This should help stabilize the idle.
Aug 31, 2008 at 1:15 AM
