2001 GMC Yukon Fuel pump replacment
HARTLEE
Engine Mechanical problem
2001 GMC Yukon V8 Four Wheel Drive Automatic
2001 GMC Yokon
Can a Carter VSICTRP 4070 electric fuel pump be installed into the supply line to replace the stock pump?
A stock pump costs $300.
A 4070 costs $75
Apr 28, 2008 at 8:39 AM
MERLIN2021
  • 17,250 POSTS
about 220.00 at rock auto plus ten for a new wiring harness, which by the way did you unplug it and check for corrosion, or melting?
https://images.2carpros.com/forum/automotive_pictures/62217_Fuel_Pump_2.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Harness_FP_1.jpg
http://www.rockauto.com/catalog/raframecatalog.php
Apr 28, 2008 at 8:48 AM
  • 75,988 POSTS
If it can produce the correct pressure/volume go for it-
Apr 28, 2008 at 8:49 AM
