Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Yukon
Trouble Codes
P Codes (Powertrain)
P0400 - P0499
P0440
2001 GMC Yukon diagnostic codes
2001 GMC YUKON
145,000 MILES • V8 • AWD • AUTOMATIC
SHERRY JOHNSON
MEMBER
1 POST
What does it mean when the repair code is P0440?
What should I fix?
Thanks, Sherry
Feb 12, 2008 at 6:15 AM
DENNYP
Experienced Mechanic
P0440 is an EVAP system fault. You first need to make sure your fuel cap is tight. If that ckecks ok, then you will need to take it to a shop that is equipped to test EVAP systems.
Feb 26, 2008 at 12:52 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
