2001 GMC Yukon ABS pump
161,523 MILES • V8 • 2WD • AUTOMATIC
DURRELLROBERT
The pump for the ABS will not shut off (runs all the time even after key is removed) unless I disconnect battery or remove the 60 amp fuse. What is the likely cause and what if any part + number do I need to order.
Jan 26, 2008 at 6:00 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the EBCM (electronic brake control module) is stuck on. No relays external, power right to the controller.Might be shorted internally
Jan 27, 2008 at 1:10 AM
