2000 GMC Yukon TPS
RIOSTREVINO
Shakes or Wobbles problem
2000 GMC Yukon V8 Two Wheel Drive Automatic
Over powering, idles normal but drives at 5 miles an hour. shakes and wobbles when sitting in idle.
Jul 25, 2010 at 9:57 AM
EDWARD.S
  • 166 POSTS
Hi, Is The Check Light On? If so, Then Have The Computer checked for codes first.Also Look For Any Vacumn hose That May be disconnected.
Hope This Helps You,
Good Luck
Edward S.
Jul 25, 2010 at 10:10 AM
