2000 GMC Yukon Low range
16,000 MILES • V8 • 4WD • AUTOMATIC
DSHERLIN
My vehicle has a push-button selector for 4 wheel drive high and 4 wheel drive low. It will go in 4 wheel drive high fine but will no longer go in 4 wheel low. When I push the button it blinks as if it's trying to convert but nothing happens and it never converts. I was told by a local dealer that some sort of computer module had gone bad and that there were no real mechanical issues. However I was also told that the repair would be about $1200. With high mileage I'm not interested in spending that kind of money but I'm thinking I could possibly do the repair myself. Can you please tell me what part (name, item #, etc) is probably the culprit and what would be required on my part to replace it? Also, what would a good source be to find the part economically? Thanks and Merry Christmas!
Dec 22, 2008 at 1:50 PM
MASTERTECHTIM
  • 4,750 POSTS
well speaking from the most common problem with this drive is the 4 wheel drive encoder motor. it is the electric motor on the side of the transfer case that shifts the fiork in the transfer case. i have seen them, online for under 200 bucks. hope this helps
Dec 22, 2008 at 11:30 PM
