2000 GMC Yukon COOLANT
110,000 MILES • V8 • 4WD • AUTOMATIC
REDMNOND0312
I am loosing a lot of coolant out of radiator, conducted block test came out negative, solution was still blue, so what shall i do, checked oil stick nothing but oil on stick with normal color.
Dec 15, 2009 at 1:45 PM
  • 31,937 POSTS
Hi there,
you will need to have a cooling system pressure test done, do this hot with the heater on, this will locate any external coolant leak,and have the pressure cap tested as well.
Mark (mhpautos)
Dec 15, 2009 at 1:50 PM
