1999 GMC Yukon oil leak
1999 GMC YUKON
78,000 MILES • V8 • 4WD • AUTOMATIC
BUSSAPOW
After replacing the water pump I have an oil leak. I can't identify the source. It seems to be in the area of the water pump. It could possibly be from the power steering pump. Question: Is an oil leak possible from changing the water pump? No coolant is leaking. Thanks!
Mar 24, 2009 at 4:51 AM
DOCFIXIT
  • 18,828 POSTS
Most likely the timing chain cover gasket
Mar 28, 2009 at 6:16 AM
