1999 GMC Yukon Is my starter gone
1999 GMC YUKON
261,734 MILES • V12 • 4WD • AUTOMATIC
KELLEN18
everything in the car works it just won't start there's no cranking or clicking or anything is my starter gone?
Apr 2, 2008 at 7:23 AM
MERLIN2021
  • 17,250 POSTS
If you get no clicking, and you KNOW the battery is good and cables are clean and tight at both ends, find and replace the starter relay! Check IGN A (40 amp) fuse and IGN C (20 amp) fuse in underhood relay center, thats also where you'll find the relay...also check CRANK (10amp) fuse in leftinstrument panel fuse block.
Apr 2, 2008 at 7:27 AM
