1999 GMC Yukon hesitates
90,000 MILES • V8 • 2WD • AUTOMATIC
RAZORSMITH42
When accelerating, the truck hesitates then jumps, hesitates then jumps. It seems to even out after getting up to about 40mph or so. It also seems to be worse after a rain. We just had the fuel pump replaced and the distributor wires and plugs replaced a year ago.
Jul 5, 2008 at 9:58 AM
  • 75,988 POSTS
Possible Causes of Engine Hesitation
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jul 5, 2008 at 1:08 PM
