1999 GMC Yukon car wont accellerate
YUKON DRIVER
Engine Performance problem
1999 GMC Yukon V8 Four Wheel Drive 127369 miles
i push on the gas pedal car boggs down and wont accellerate
Jul 31, 2010 at 10:33 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 1, 2010 at 12:46 AM
